Advice on planned OCing/cooling
EnderW
Planning to finish the following system this weekend, do you guys think it is feasible?
Case: Fractal Nano
PSU: EVGA SFX with Silverstone bracket
MB: Gigabyte Z390
CPU: 9600K
RAM: 16GB b-die 3200MHz C14
GPU: MSI Ventus 2080 RTX OC
I’m hoping for a 5.2GHz overclock on the CPU. For cooling I have 2x Noctua 140mm intake, 1x 120mm intake, 1x 120mm exhaust. For CPU heatsink I have a Thermalright HR-02 but just got a U14S I can swap in if necessary.
Basically just asking if my hopes for 5.2GHz from this is realistic and any advice on the cooling plan
If you crank all of your fans up and can keep your voltage down you may be able to hit 5.2 but realistically your probably going to need water-cooling to get that high and be able to maintain stability.
GL and have fun!
