Advice on new core2duo build
omegaw666
This is what I have come up with. I haven't built a desktop in over 4 years...
suggestions?
Antec P180B
e6600
Corsair XMS 2GB 675
Asus P5W DH Deluxe/Wifi
Antec NeoHe 550W
WD Raptor 150GB
evga 8800 gts
samsung 225bw
floppy/dvd
Do you plan on OC'ing? If so, go for some DDR2-800 ram. If not, then you're set. Though, I'd choose different RAM. Oh, and I'd go for the Corsair 520W PSU instead of the Antec, though the antec is nice, too.
I don't plan on ocing much if at all. I was just talking to a friend and it occured to me that the 965 chipset might be better/cheaper? I don't plan on using sli/crossfire either.
Aren't there issues with the P180's panels warping and the door coming off soon?
It's a good case, but you should check out other companies like Lian-Li.
I heard they fixed the problems with the side panels. Also, if you do get one that warps, Antec has a good warranty policy.
Yes, if you don't plan on SLI/Crossfire, go with a P965 Express chipset based board. The Gigabyte DS3 is very popular, as well as the overpriced P5B-E/P5B Deluxe boards. If you want cheaper, theres a Biostar TForce and a Foxconn P9657AA. Also, the nForce 650i Ultra/SLI boards should be coming out soon.
I heard of all the problems with the evga 680i and sata....
the nforce 650s probably will have same problems?
