Advice on new build
kjdocs
**BTW, sorry if this isn't the right forum***
going to be doing a new build in earl 2012. I have never built my own, so i was hoping someone could tell me if this combo i have listed out so far is compatible, as well as desirable (not sure on things such as fans and power supplies.
I'm certain i want a 580 no sli at the moment. I'm also certain i want intel i7. I'll reuse my SoundBlaster card for now or just use the on-board included with the MB. (Old pc will be new Media PC).
1 Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
Item #: N82E16811147153
1 ASUS P8Z68-V PRO/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Item #: N82E16813131790
1 EVGA 015-P3-1580-AR GeForce GTX 580 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Item #: N82E16814130587
1 SeaSonic Platinum-1000 1000W ATX12V / EPS12V 80 PLUS PLATINUM Certified Modular Power Supply
Item #: N82E16817151105
1 Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I72600K
Item #: N82E16819115070
1 Seagate Barracuda XT ST32000641AS 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822148506
1 ZEROtherm ZT-10D Smart 120mm MFDB CPU Cooler
Item #: N82E16835887037
Might want to move this post over to the General Hardware forum - you'll probably get more responses over there.
I will say that the only difference between the -V and the -V Pro is that the Pro adds 2 extra SATA 6GB ports (on a Marvell controller) and 1394 Firewire support - so unless you need those two things you can save money by just getting the vanilla -V, it is otherwise the same as the Pro.
Also, if you're going to get the GTX 580, keep in mind that the Rosewill Challenger case might not have enough room for even a single GTX 580: That case has all of its expansion slots permanently restricted in length. IMHO the Rosewill Challenger case can only accommodate graphics cards shorter than 10.5 inches comfortably, while all GTX 580s are at least 11 inches long. I tried this on a friend's PC with that exact same case, and a GTX 580 is a very tight squeeze inside that case (the front end of that card is pinned firmly against the case's fixed, nonremovable drive cage.) For best reliability you want to leave at least one inch of room between the front edge of the card and any obstructions from the case.
Thanks, defiantly head to general hardware.
Thanks E4g1e, thats the kinda stuff i don't want to miss.
