I just got my antex micro ATX case in and it is small, really small. My intent is to make this box into my HTPC server for my Vista 64bit Ultimate Media Center, which would still fold 24/7. What I need advice on is a mobo to pair up with my E6600.
the problem I am having is there are a lot of foreign choices as far as chipsets... I'm used to P35, X38, X48, etc... My options are Intel Q33/Q35, Nvidia Geforce 7000, ATI, G31/G33/G35, G965, Q963/Q965, Intel 945/955/975... So which is the best?
Requirements:
1. 1333 FSB
2. Overclockability
3. 2 memory slots
4. 2 Sata slots
5. 1 PCI-E slot
I'm leaning toward this but do need some advice if anyone has experience with chipsets or microATX mobo's.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128078
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128085
Thank you!
Requirements:
1. 1333 FSB
2. Overclockability
3. 2 memory slots
4. 2 Sata slots
5. 1 PCI-E slot
or
Thank you!
