Hey guys, thanks for taking a look and for any advice and thoughts you can offer. after Ausing [H] reviews for many years I figured I'd use the forums for advice on something I don't know much about... mATX builds. I tried it once about 6 years ago but wound up returning parts and getting a full size setup. But cases seem to have advanced a lot in that time and offer larger fans and space for full size parts while still being relatively compact. So it seems like a good time to give it another go and ditch this super tower I've had forever!
I've been out of the hardware thing for a number of years now so if anyone has a moment to take a look at my parts list and tell me if I have any glaring errors or if there is something better to be suggested or anything like that... It would be appreciated. Or if something better is a couple months out I have no need to build right now but want to by early next year.
This will be mostly used for gaming, with a bit of photo editing and basic video editing on the side. I'm really only worried about gaming performance as photo editing is plenty fast on my current computer and video transcoding time doesn't matter to me.
Case: Corsair Obsidian 350D. Small enough to go on top of a desk while still having 4 140mm and 1 120mm fan and enough room for a 15in graphics card seems too good to be true. Am I missing something? I wouldn't mind smaller, but don't want to lose support for higher end graphics cards and a 5.25 bay for my Blu-Ray.
CPU: Intel Core i5-4690. I know I could get the unlocked version for a little more but I have no interest in overclocking anymore and with modern games and resolutions does it really make much of a difference with the CPU? Also any reason to go AMD? They seem to unfortunately using about double the power for similar performance to an Intel chip? And what about the i7's, are the worth the extra cash?
MoBo: ASUS GRYPHON Z97. I know I'm not overclocking but you need a solid foundation for the rest of the build. Though I am open to less costly but still top notch quality suggestions. I'll hopefully just be upgrading the graphics card for the next 4-5 years or more, so durability is key.
RAM: I have no clue. With RAM speeds hitting what their at and the board supporting 1866 I'll likely go that speed. But do timings really matter anymore? You can get anything from low timings to low voltage. Any pros / cons / suggestions on this? And 16gb or spring for 32gb since I plan on keeping the same basic setup and just upgrading the graphics card for hopefully 4-5 years.
Video Card: I could use some suggestions here as well. I game at 2560x1080 with a strange widescreen thing that I love. I'm also kind of building a new system because Star Citizen will be out sometime soonish and its going to supposedly eat our hardware for breakfast. I'd love to go crazy but with building the rest of a system I'm thinking $300 and under. So AMD 290X, 285 or NV 270? I think that's the best of that price range? And how long are these things anyways? If I wanted to go crazy with a 295x2 would it fit in that corsair case?
PSU: I have a SeaSonic Modular 660w Plat Certified that I picked up a year or so ago. So as long as that's going to have enough watts I think I'm set there.
CPU Cooler: I'm looking at the Corsair H110. I've been using a H80 for a number of years now and it's solid and I like how it takes weight off the mobo and dumps heat out of instead of into the case. Anyone know if you can run the fans double sided? The pics on the corsair site make it look tight but they don't offer any perspective. Or am I better off air cooling?
Thinking of cooling, anybody have any thoughts on a fan controller vs letting the mobo do it's own thing?
Thanks for reading. And thank you in advance for any suggestions, thoughts or advice.
