Advice on Home Theater
BAC4D00R SP1D0R
Hello all,
I have recently bought the Klipsch Quintet 5 speaker setup, and I am looking for a good receiver and sub to go with them. I bought the speakers for $200. I am looking for a receiver around $300 and a sub that is around $300 as well.
I live in an apartment and will continue to do so for the next 5 years.
I have a friend at Bestbuy that may hook me up with a discount on the receiver and sub.
I just went to Bestbuy and saw some receivers.
$250 Receivers
Pioneer - 400W 5.1-Ch. 3D Pass-Through A/V Home Theater Receiver http:///K8bMK I am not sure how Pioneer is? I have always thought of myself as buying a Denon, but thought I would include it to see what you guys think?
Denon - 550W 5.1-Ch. 3D Pass Through A/V Home Theater Receiver http:///ElyXT http:///C8clr I'm not sure what is the difference between these two models. I was recommended this at bestbuy. I think bestbuy employees get a good discount on Denon and its also a cheap reciever. I wish it have more HDMI ports but oh well.
Sony - 945W 7.1-Ch. 3D Pass-Through A/V Home Theater Receiver http:///TgscJ Why is this receiver so cheap? 7.1 and better wattage then any other receiver? Do Sony receivers suck?
More expensive (but I should get a discount just like the smaller receviers)
Denon - 600W 5.1-Ch. 3D Pass Through A/V Home Theater Receiver $400 http:///9iyz7
Denon - 875W 7.1-Ch. 3D Pass Through A/V Home Theater Receiver $579 http:///RYDmR This is probably too far outside my budget even with discount. Futureproofing would nice but I'm guessing that buy the time I get another system I will be able to toss everything out and start anew whith much better hardware.
Subs
I dont need to blow out my apartment building so I was thinking this Klipsch - 8" 350W Powered Subwoofer http:///C2pvU
If anyone thinks any of my parts are complete shit then feel free to let me know. Feel free to recommend anything else to me!
If you plan to live in an apartment for the next few years, don't bother with a sub. Don't be that.guy.
Are you opposed to buying used equipment?
How many HDMI inputs do you need?
Do you need zone 2?
zone 2 is use if you wanna bi-wire your front speakers, no?
NO. Zone 2 is used for a second room or a patio. Bi-Wire is running two sets of speaker wires from the same speaker binding posts (doubling the wire size in effect). Bi-amp is what you are thinking of and offers very little to no improvement on an AV receiver. I actually tested this out on my Onkyo TX_NR3009. Besides, you have to get an AV receiver that is bi-amp capable. Don't bother. Go with an external amp if you need more power.
*Some* receivers can do this (but I strongly suggest that you DO NOT)
The intended (and proper) use of zone 2 outputs is to have a second, separate source to a different set of speakers (like some on your patio).
Many AVRs now claim to be able to bi-amp over their zone2 outs... It's a terrible idea.
I contend that the vast majority of people who have set up biwire systems don't get any benefit and probably have negative consequences.
Your links are borked, so I can't tell what you're looking at.
For the Denon's, read this for xx12 model differences and this for xx13 model differences. I purchased a 2112CI earlier this year for $450 new, but its no longer available new from most places. My dad purchased one less than a month ago for $325 as a refurb.
The two major things for me in the receiver features were the AudissyEQ XT room correction and the network connectivity, so with xx12 Denon optoins, it was the first one that met the requirements I was looking for.
As for the sub, I had a much bigger room to fill, so I picked up an Outlaw LFM-1 :-D. I did listen to the Klipsch at Best Buy that you've mentioned - if you can get it for a good price, I see nothing wrong with it.
Bi wiring is a joke, the only time it makes any difference is if you are using some amazingly awful speaker cable like 24 gauge or something, then by all means double up on it.
Bi Amping can be good depending on your specific set up, but you can only bi amp speakers if they are bi amp capable (ones with two sets of binding posts, top binding posts controlling tweeters/midrange driver, bottom controlling bass driver(s)). This can be good if you have a receiver and an amp and want extra power or you want an effective way to bass manage your system because there's either too much or too little bass or you want to have some control the crossover. I bi-amped my system because I could, but then I took it down because it really offered me nothing over what I already have since I already had plenty of power and balanced speakers.
And zone 2 bi-amping can be an awful idea since your speakers may be running in parallel with this (depending on the design of your receiver) which will lower the impedance load on the receiver and can cause it problems/ trip the circuit protection (depending again on the quality and power capability of it and impedance ratings of your speakers)
For the sub, I'd recommend a HSU. You don't need a lot of power, but you still want something that'll extend to 35hz or below. The STF-1 fits your budget at $299 (plus S/H): http://www.hsuresearch.com/subwoofers.html
I bought the VTF-1 a few years ago based on the recommendations over at AVSForum.com. It was ridiculous overkill for our apartment, but I wanted to be future-proof knowing we'd be buying a house this year. Well, we just bought a house, and it's still overkill. I should've saved $100 and gone with the STF-2...
I would avoid Onkyo receivers if only for the heat they put out. I had one prior to my current Denon and I'm pretty sure I could've fried some eggs on the top of that thing, even when it was sitting on an end table vs inside the entertainment center. A few friends with other Onkyo models have the same problem.
Sub-wise, I have a 10" 400w Klipsch similar to the one mentioned. I've been happy with it, but I'm not one of those "OMG BASS!!" people. I just like some depth to my sound. In an apartment, you're not going to have it turned up very loud anyway, so if it were me, I'd just pick up a cheapie Polk (10" for $120 or 12" for $250) and call it a day. Polk makes decent budget subs.
Tell your friend to use employee purchase program to get klipsch sub ... Receiver any will do. Don't be that guy = turn it down but don't pass up opportunity for klipsch sub
