Advice on good overclockable Motherboard
Albanu1800
On my of my pc's I want to change my motherboard and overclock it & with the current setup it will not allow me to. I don't know much about Intel mb's but I want something that's a nice little overclocker.
Because the pc is kind of old I don't know if I have to change the processor with a new mb purchase. At 1.8 ghz I feel I should get more out of it.
Hit the link on the specs and no this is not a joke:
http://support.gateway.com/s/PC/R/1014168/1014168sp2.shtml
I've modified some of the specs by adding and changing a few things:
Changed the memory to Corsair XMS2 - 2.5gb ot memory pc-5400
Added Radeon HD-2600 pro PCI express video card
Took Vista off and put XP Sp2 on it.
Any advice on a new MB for my pc would be appreciated.
I noticed that the spec on the Gigabyte have FSB 1333/1066. My C2D has FSB 800, is that cool?
my wife has this exact machine.... and yes it doesn't overclock for beans. 2 things, 1, replace the power supply. the stock unit runs what's there, and little else. and 2 pick up an aftermarket cooler whilr you're at it, as the stock one is 1) proprietary and 2) garbage. the ga-p35ds3l should work fine, not sure if the media ports will work, as i never looked to see how they connect to the board.
I've easily achieved 2.88GHz with the E4300@1.375vcore with stock HS/Fan on a Gigabyte P35, didn't try further because I don't plan on getting a third-party cooler and RAM is only 667MHz.
edit: and yes, being able to reach higher FSB is cool, at home I'm using also a P35 with an E8400@4.00GHz :D
Ok thanks, going to order this MB next week, maybe the Egg will have a special on it. It's got plenty of good reviews..
I'm on an Abit IP35-E and I'm at a stable 500mhz fsb 8x500mhz E6750 @1.48v. I'm pretty sure I can go further but I stopped at that speed cause my temps are at 40-45c at idle and 70c+ at load using a Thermalright 120. I am however 24/7 stable.
I have the ds3l gigabyte board and a asus maximus and the gigabyte is an excellent OC board if you dont care about SLI or RAID. I highly recommend it
One more thing the gigabyte board is cheap $70-$80 brand new and I have seen them for $40 on the forsale trade fourm.
Really? Thanks for the headz up. Yeah with this pc I don't want SLI or Raid. I bought the HD2600pro just for light gaming. When I get all my software updated I'm gonna put Vista back on there for DX10.
