advice on case modding
First of all, your exhaust fan (the one on the back of the case) needs to be turned around, so that it is blowing air out of the case. As it sits, it is intaking air. Second, the fan on your CPU cooler should be on the front of the cooler, blowing air through the fins, and out the exhaust fan. (unless you have it on the back of the cooler, "sucking" air off the fins, in which case its cool if it gives you okay temps.)
As far as modding, its really up to you. IMO, I would either sleeve those power cables. Or better yet, run them behind your mobo and hide them altogether- check out the "rate my cables" thread for some good ideas. Maybe paint the inside? Add some lights? Everyone has their own idea of what makes a case look good, at the end of the day that is what matters, is what YOU think looks good. Just browse around the case mod galleries and get some ideas.
ya i will change that i had it set like that because it was winter and the back was toward the window where i would get 37c temps so i will change it back
