I am putting together a pc for a friend. He has just started using computers so right now he doesn't need top of the line(He is currently using a pentium III 500mhz). Criteria is that he wants to be able to upgrade in the future. I'm leaning towards a AMD processor due to budget considerations, however I would like advice on stability, I would like as stable a system as possible. Gaming isn't important now however he probably will start to do so as he learns I plan to get a midrange card. After research I believe I will need a PCI express board so upgrades are possible(not sure how long AGP will be viable) and I am unsure which socket type board to get, considering a upgrade for the processor is probable after a year or so.To summarize,
What motherboard would you recommend based on the above criteria?
Edited title for typo
