advice on airflow on Cosmos
I have my MCR-320 mounted in the top of my cosmos 1000, i currently have air being pulled into the rad, through the top of the case. Should i be pulling air into the case or should i be pushing the air out through the top?temps are kind crappy, but that because i have the rad mounted inside me thinks
different people will suggest you different things
some like to pull air in the case through rad
some like to push the air out of the case through the rad
could you try both variants? and see what suits you best (gives better temps)
but if i had a big enough case to have the rad mounted inside, i'd prefer the air to be pulled in the case from the outside
so that the rad would always have the coolest airflow possible
