Advice on a new tv?
MrGuvernment
Hey all,
long story short, friend didnt have good grip on the corner of my sony tritron 32" tv and dropped it!!!!!
SO now i want a new tv.
Problem is being in costa rica, my option are very limited - any good tv is $3k +.
i am aiming for the $2k, i went around to alot of places today and the best of what i could find was basically:
Samsung
43" Rear Projection Television
Model: SP43Q5HL
http://www.samsung.com/au/products/tv/rearprojectiontv/sp_43q5hl.asp?page=Specifications
Now i do want 1080i HD and such, it says this tv is HD ready.. ? lost on that one... would i need to buy something to make it HD ready ?
it only has component RCA plug on it, no DVI or HDMI...
  • Specifications
    Screen Size: 43"
    Screen type: Wide
    NTSC: 3.58
    Cable / Hyper Band
    VHF/UHF (2-12 / 21-69)
    Input Signal: 480i/480P/576i/576P/1080i
    Display Mode: 100Hz/Progressive
    Optical System RealFlect System TM
    Screen(Anti Glare): HD Fine Pitch Screen
    Digital Comb Filter: 4H
    Digital Noise Reduction
    Low Noise Amplifier
    CRT burnt Protection
    Self FocusTM
    4 Picture Modes
    Color Temperature Adjust: 5 Modes
    Aspect Ratio Mode: 3 Modes
    Stereo Type: Nicam / A2 Stereo
    Auto Stereo
    Sound Mode Select: 5 Modes
    Auto Volume Leveler (AVL)
    Surround System: Virtual Dolby
    Sound output (Total): 30W
    Features: ATM (ATS), Channel Memory, On/Off Timer, Sleep Timer,
    TTX: FLOF
    Child Lock
    Plug & Play
    Absent Power Off
    Auto Power Off
    OSD Language: En/Thai
    Still Picture
    Input Labeling
    AV input 1
    AV output R1
    S-Video input F1/R1
    ANT.(RF) R1
    Smart Component (Y/Pb/Pr) R2
    Remote Control Universal
    Power Supply Free voltage
    Power Consumption 230W
    Stand-By Power 3W
    DimensionsDimensions: (WxHxD) mm 1035x888x510
    Weight (kg): 40
So i was leaning towards this Sony, $300 more, but has HDMI and VGA and component
But, what has me, the tv says on the back it was made in November 2004.... - they had HDMI back then ?
It also says on one review i need an HD receiver as well to use HD on this - so that means if my DVD player has HD it wont show on the TV with out the receiver - even thought on the back of the TV it lists the HD resolutions and has component right below them ?
  • Inputs And Outputs:
    Component Video Y/PB/Pr (1080i/720p/480p/480i) Input: 2 Rear
    Composite Input: 1 Front/3 Rear
    HDMI Interface: 1 Rear
    S Video Input: 1 Front/2 Rear
    RF Input: 2 Rear
    Audio Out: 1 Rear
    General:
    Power Requirements: AC 120V 60Hz
    Power Consumption: In Operation: 295W
    In Standby: <1W
    Audio:
    Auto SAP
    MTS Stereo
    Steady Sound® Auto Volume Control With BBE® Audio Effect
    Auto Mute (Tuner)
    Audio Output (Variable/Fixed)
    TruSurround® SRS® Audio
    2 Speaker System (20W X 2)
    Video:
    Auto Channel Program
    Trinitone® Colour Temperature
    Caption Vision (CC)
    Channel Label
    Channel Skip/Add
    Clock/Timer Two Event
    Energy Star® Compliant
    Favourite Channel with Preview
    Picture Freeze
    Picture Jump
    On Screen Display (English/Spanish/French)
    Program Palette™ Presets (Vivid/Movie/Standard/Sports)
    Sleep Function
    Speed Surf™ Channel Selection
    V Chip Parental Control
    Video Label
    Wide Mode (Normal/Full/Zoom/Wide Zoom)
    XDS (Extended Data Service)
    Manual/Auto (Flash Focus™) Convergence
    ID1 Detection (Auto)
    Supplied Accessories:
    Instruction Manual
    Remote Control RM-Y916
    AA Battery (2)
    Weight:
    135 lbs. (61.3kg)
    Dimensions:
    42 3/48 " x 402" x 24" (1086 x 1017 x 609 mm)
okay, think i understand now i read it better
HDTV Ready, means just that
The TV can display HD resolutions, so if i hook my PC up to the system - it will run HD resolutions BUT if i want to watch HD TV - i need the receiver?
Also, since the sony only has a VGA port, can i get HD resolutions out of the VGA port or will it look like crap - like using VGA on an LCD with your comp ?
Could anyone point me to a good forum that maybe able to assist me in this ?
