I'm upgrading from my current system (XP 2400+ @ 2.5ghz, 1gb pc3200, 9700 pro) for college. I don't need to do that heavy of gaming, but I would like to be able to play newer games at least at medium settings.
Here's what I'm thinking:
Proc: AMD X2 3800+ AM2 = $159
Mobo: Biostar TForce 550 nForce 5500 AM2 = $86
RAM:OCZ 2gb PC2-6400 Platinum = $130 AR
Video Card: evga 7600GT KO = ~$140
Case: Lian-Li V300 = $100
PSU: Enermax Liberty 400W = $75
Optical Drive = NEC 3550A which I already have
Hard Drives = I have a 200gb and 300gb, but I might buy another 400 or 320 (I'm going to put either 1 or 2 of these in external enclosures).
Total should be around $690 from the above, but I want to invest some money on good after market cooling that is SILENT since it will be in my dorm. I'm also going to be buying an HDTV tuner so that I can watch tv on my 2407FPW.
The reason I'm going AM2 rather than conroe is because the conroe system would be a while before I would get one, and it would be more expensive. I think the X2 will be sufficient at least until I get a better video card (I'm waiting until DX10 has been out on the market for a while).
Some questions:
How hard would it be to mount a 120mm fan in that case?
Is that case easy to work in?
Is the mobo I picked the best for the price? I don't need integrated video but integrated audio would be nice so that I don't have to use a PCI slot for it.
Since the evga is OOS, what 7600gt should I get in place of it?
Thanks for any help!
Some questions:
