Advice on a motherboard
SDNYC09
I need help picking a motherboard i can fit 3 7970 water cooled and still have one 4-8x pcie slot for a pcie ssd...
any help would be great
Keeping current CPU so 1155 is the socket ... I looked at that Asus Max board It dosent look. Like it would fit all 4 does anyone have any personal experience with what I'm asking?asking
Dookey that revolution looks like it might work lemme read up on the specs thanks man
The Maximus has a PCI-e 4X slot at the very bottom, and if you're watercooling three cards, I think you'd be fine otherwise.
But I have no personal experience with that board.
Good luck.
With watercooling, those cards will be able to fit in a single slot, and those double slot brackets can be replaced with single slot brackets, freeing up the slot for use.
Yea it would work, but where do i find a single slot bracket that will fit that cards input slots?
Koolance comes to mind. Most waterblock manufacturers will also sell single slot brackets.
