A few weeks ago I noticed a slight ringing in my ears that would go away after a few seconds. This was after about two weeks of serious game'n in the evenings while I wore my headset for extended periods of time. A friend suggested that I might need to get an open headset instead of the closed type that I prefer.
Is there that much of a difference?
For the most part I do not enjoy loud volumes. That always seemed like the advantage of closed earphones. I did not need as much volume to hear the little details. So any input on this would be appreciated. I know little about the difference between the two types.
And if anyone can suggest a good quality headset that is open please do so. (if I do need to make the switch) I would like to keep the budget around 100 but no higher than 150. This headset will only be used while I game and need voice comms.
