Advice needed...
donkey33
I need a new monitor and want to get a 19". Since the LCD's are too expensive for me, I'm looking at getting a CRT.
I did want to get a Mitsubishi 930 SB or it's equivalent NEC but here (Australia), they are a bit too expensive for me at $580. I also looked at the Viewsonic P95F+ but it's at $570 which is too much as well.
So, I've narrowed it down to 3 options that are a little bit cheaper.
Well, kind of 2 options as 2 monitors are Mitsubishi and NEC and I've been told they're the same like the 930 SB and the other NEC.
The first is the Mitsubishi 93 SB ($445) and its equivalent NEC FE991 ($485). The 2nd is the Viewsonic G90F+ ($366).
I know about the Mitsubishi and the NEC and they're good monitors but I don't know much about the G90F+. I'm leaning towards it a lot more than the Mitsubishi/NEC because it's only $366 and I'd be prepared to spend that.
So, can anyone tell me if the G90F+ is a good monitor and what they think of this thread? I've been using a 17" Magview non-flat so I suppose anything would be better.
Thanks and the URL's are to the monitors I'm deciding on.
http://www.nec.com.au/products/index.cfm?objectID=1C4AA5E4-5913-4AFD-9E976668CDCB98DA
http://www.mitsubishi-electric.com.au/PRODUCTS/COMPP/MONITORS/DP93SB.htm
http://www.viewsonic.com.au/products/productspecs.php?id=103
Your links are busted. The ... got into the link somehow. As for the screens I don't really know much about any of them. I have a preference for shadow mask tubes & have been buying Hitachis lately.
Personally I'd probably get the Viewsonic since I like shadow mask tubes. They all look pretty equivalent to me, and all three are well known makes.
Which one has the best warranty? I can't seem to find it on the specs.
Also, I don't think my eyes could really handle a screen resolution of 1600x1200 so at max, it'd be run at 1280x1024.
Would that make a difference as to which I should choose?
Thanks.
