AceCurby99
- Nov 9, 2005
I'm building up a PC and am looking to add a water cooling system to it. Here are the upcoming specs...
AMDFX57
2x NVidia 7800 GTX
2x 100GB 7200 RPM HDs
2GB PC3200 RAM
Now, I've been doing a little research about different companies and there blocks, radiators, etc...there seems to be an agreement that either DangerDen, Swiftech, or DTech is the way to go.
Heres my question - w/ each of these, which Radiator, Pump, and resevoir should I go with if I want to run a CPU block, both GPU blocks, and the MB block. Should I add a HD cooler? My goal is to eventually overclock this thing, and since I'm poor, I got one shot at this - if anything breaks, it sits until I can rob the local 7-11 again...
Fire away boys and girls...I was suggestions, advice, comments, etc. Thanks!
AMDFX57
2x NVidia 7800 GTX
2GB PC3200 RAM
