Advice needed on system upgrade
M@
This is my current system.
motherboard: Asus A7N8X-e
CPU: Athlon XP 2600+ Barton running at 195mhz fsb (almost 3200+)
video card: Nvidia Geforce 6800GT 256mb
hard drive: Maxtor Ultra 16 300gb hardrive
RAM: Mushkin Level 2 PC3200 2x512 running at 200fsb dual channel
I have about $400 max to spend and need advice on what I should upgrade to get the best performance for the money. I'm using the system mostly for games and some fileserving.
Thanks in advance.
Thanks for the advice.
Yep, the 6800 is agp. I considered putting that in but figured people would know by what motherboard I was using.
No Problem :)
Honestly, I think a CPU/mobo upgrade is your best bet on that budget because the 6800 is a pretty beefy card. Hell all I've got a is a 9500 Pro and I can still play pretty much any game out there.
Good luck on your upgrade man :)
