Advice needed on Power Supply
zoobaby
Need to replace a PSU ASAP. Been put of the loop on what is good. Looking for advice for PSU for following system:
E6600 c2d
8800 GTS
2 Gig Ram (Current ram is OCZ DD2 7200, but one stick is not working.)
2 Sata drives
2 DVD drives
1 floppy
5 120mm case fans
I will OC some, but not pushing too hard. Thanks!
Silverstone Zeus 650 watt is $110 at Newegg right now.
Corsair 620HX is also a very good (arguably better) option.
You should be fine with the 520HX, actually.
Pretty open on price. Probably under $200 although spending less is always better as long as quality doesn't suffer.
Well right at the 200 mark the Infiniti 720 or a little less the Infiniti 650w are going to be right at the top of corwd.
Thanks Paul...you are on top of it...I came back to edit and you had responded.
The edit I was going to make was to ask how are Seasonics PSUs? I can snag one locally if hey are worth the time.
I would put the M12 in the same general class as the Infiniti. The original S12 is getting a little long in the tooth and I just got in one of the S12 II's. Overall if you can snag one at a good price I would do it. But if it is a S12 original versus the Infiniti at compatrable price I'd get the Infiniti. I won't have a really good answer on the S12 II's for a little bit still, sorry.
