Hey bit-techers,
After not being able to find a mini ITX case that's just right for me, I've decided to design and build my own.
As it will be my first custom case, I decided to use acrylic as I believe it'll be easier to make a scratch build from as I have no experience with designing or building scratch cases. Also, I'm a student so my budget will be limited to hand tools. I did ask my friends if any of their unis have a workshop but it seems none of the unis in London seem to have a workshop.
Hardware:
The hardware that I will be using will consist of:
CPU: i5 3330S
GPU: MSI 7850 1GB OC
Motherboard: AsRock B75M-ITX
RAM: Samsung Green 8GB
PSU: Seasonic SS-250SU 250W Flex ATX
Intake fans: Gelid Slim PL Blue 120mm 15.8mm thick fans x2
Not very high end, but more than enough for what I do and need.
Concept: (V2)
Previous version (V1)
As you can see, I've tried to fit my case under 6L (~300x70x270 = ~5.67L). I'm currently using the setup listed above without a case laid horizontally along with a Xigmatek Praeton LD963 cooler without the fan (instead using the Gelid fans to blow over the PSU and CPU cooler) and it runs cool enough for my liking.
The white outer acrylic will be 3mm in thickness and will consist of one sheet bent with a heatgun on all 4 corners, with a separate piece that will be attached via a hinge to allow easy access to the hardware. The front and back acrylic pieces will be 5mm in thickness to allow me to screw the outer shell pieces on.
Questions:
So as I'm new to this, I have several questions to ask.
1. Laser cutting vs hand tools: How hard would it be to do all the cutouts by hand? Would it be more advisable to simply learn how to do CAD drawings and send it off to get it laser cut instead?
[Update: Still deciding on best way for the vent cutouts.]
2. Tools: If I were to do this by hand, what tools shall I use? Would a dremel be fine for everything if I take my time? I will be needing to countersink some things such as the fan holes and will definitely need to thread the screw holes, would a dremel be fine in this regard too?
[Answered: Each task requires a different tool.]
3. Graphics card support: As the back plate for the case will be 5mm thick, how should the graphics card be held? The only real solution I can come up with is to shove a small piece of acrylic in the gap between the acrylic and have it screwed on either side of it, would that work well?
[Answered: Simple acrylic piece]
4. Painting: I would like to paint the Flex ATX PSU case white to match the case, what exactly are the steps? Is it simply sand, primer then paint?
[Answered: Yes]
5. PSU safety: As the case is sealed off, would it be safe to have the top cover of the PSU off to allow more air flow into the PSU? (Stock 40mm fan is loud)
[Answered: Safe but risky, I've decided to cut out a hole and glue mesh on instead of taking the whole cover off]
6. Custom length cables: I want to make custom length cables using all black cables, is it safe to unsolder all the current cables from the board and resolder new ones on? Or should I cut off the current ones and simply solder new ones onto those?
[Update: Still deciding on what to do - thinking of just using plastidip on the wires.]
7. Power plug: I can't seem to find any low profile kettle plug (UK) to attach to the PSU so I was thinking of buying the female socket and simply soldering wires from it straight to the prongs on the PSU - is this safe enough for usage?
[Answer: Risky so I will get kettle cable and cut material off it]
8. Acrylic bending: I bought a piece of 3mm acrylic to test how it'd bend (freehand using heatgun without clamps) and the bend was not sharp at all [see here], will I be able to get sharp bends without using a wire heater if I purchase a proper work bench and clamp with a block to hold it?
[Answered: I'll pass on bending and simply glue panels and sand corners to get curved effect]
9. Gas mask: What type of gas mask will I need whilst I work with bending the acrylic? Will a FFP1 be enough, like the 3M 9312 or do I need something more like the 3M 4251?
[Answer: Yep, FFP1 is enough but you only get 1 pair of lungs!]
10. Acrylic type: Do I need to worry about extruded acrylic vs cell cast acrylic?
[Answered: Yes, do not buy extruded as it sucks]
Apologies if some of these questions sound stupid, but I really want to make sure I get everything right.
Thank you very much in advance!
Hardware:
CPU: i5 3330S
Concept: (V2)
Questions:
[Answered: Yes]
