advice needed on cpu watercooling block using amd clip
fr33ze
got a mate who wants to set up a watercooling rig but he hasnt got any holes in his motherboard to mount a water block in the normal way so he needs to find a block that uses the amd clip mechanism. i've found this block already made by wet and chilly chips but in my opinioon it's overpriced.
anybody know of any other blocks/got any advice on good performers.
Swiftech blocks and DangerDen blocks can use the socket clips. DD RBX is one of the best performing blocks that's decently priced. I noticed you're in the UK so your best bet is one of the UK Distros. Just be sure to get the socket hold down (SHD).
