Advice needed - Office build (budget)
tserts
Hello everyone, somehow I ended up in this forum, I have done some reading and I noticed that some members give very thought-out answers with in-depth analysis of the requirements so I want to give you guys a try... I'm fairly experienced, been building my own systems for over two decades, I am a little short on time lately so I would like someone who has spent more time reading the charts to point to the best solution.
This will be my main office pc, I have two monitors and main use will be heavy browsing (two browsers, 30+ tabs by midday), photo editing (I use gimp), zipping and ftp-ing. I do web design if it helps.
I want to spend around 250 euros or less, the current rig is an old P4@3200 with 2Mb RAM, it is very sluggish at times, I don't want top of the line, I want smooth, fluid operation.
I live in Athens, Greece. I can buy from EU but with shipping it is not really worth it, as my local supplier issues professional invoices and I don't pay the VAT (23%), plus he's much easier to return something faulty. This is the site (try google translate to navigate)
I want mobo, CPU and RAM. Later on an SSD will be added.
I have some older used PSUs but I have a brand new generic 400W spare which I might use, I won't be pushing it too hard.
6) Will you be overclocking?
No, actually low power consumption will be a plus.
7) 7) What is the max resolution of your monitor? What size is it?
One is 1280*1024 and the other 1366X768.
Once I make up my mind, I wasn't planning on upgrading but seeing the cost of an extra 2Gb of DDR2 ram (my initial thought) I can get 8Gb for the same amount of DDR3 1333 so a full on upgrade actually makes sense.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB3, Sata3 for sure. On board GPU seems like a good idea, read on bellow for thoughts.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
It will be dual booting ubuntu and windows 8, 64bit.
Possible scenarios:
1. A10 5800k with 8Gb, the GPU will be more than enough for my needs. Less upgrade options down the line but this will make a decent office pc for many years, easily moved and configured.
2. FX6300 with 8gb, I will use an older pci-e GPU (but what if it doesn't work?, I will go up in budget, but this cpu is much faster). What about the GPU on this mobo? Is it enough for my needs? Both monitors are D-sub, can I use both monitors with an adapter (the site says no, but if I can that is the best solution as I see it)
Both the above are about 250 euros, if you can suggest an equally priced intel build I'm all ears.
In my search I noticed that going for less than the above makes no sense, but if you can suggest an even cheaper solution I would very much like it...
Thanks for reading and for any advice you can provide! :cool:
