The situation is fairly simple. I have a spare 3TB USB HDD laying around, and would like to use an adapter to connect it into my router. The router does not have a built-in USB port, and therefore a NAS adapter would be needed.
The problem: Most NAS adapters only support up to 2TB per USB port, and the ones that support higher than that have incredibly low reviews, in fact almost all adapters do. Transfer speed isn't important to me, but what is important is I don't want cloud or remote access; only those connected to the LAN.
Advice?
Advice?
