Gaming, Occaisional encoding / rendering, Occaisional Virtualization.
$600 CDN Including taxes and shipping, before rebates.
3) Where do you live?
London, Ontario Canada
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Motherboard, CPU, RAM, case, GPU, HDD, PSU, capture card (if not now, later). 2.1 speakers.
*PS/2 Keyboard, USB mouse, combo drive.
6) Will you be overclocking?
Considering it.
currently have a 1024*768 LCD, but am planning on getting a higher resolution monitor (19, 20 inch) after this build
Tommorow, or more likely next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
10) Do you already have a legit and reusable/transferable OS key/license?
yes.
Windows xp / vista / 7RC, linux
32 or 64 bit
Post-build I'll have probably 200 max for a monitor, something above 1280*800, size isn't that much of a concern.
The only local supplier i know of is at http://megacomputer.ca , they have an online catalogue and I've heard that they can order parts, and may potentially price match. I'm willing to order online but would prefer to just go and buy parts directly.
Any advice appreciated.
Considering it.
yes.
32 or 64 bit
