I am trying to build a DAW in a very small mini-ITX case. So, I am trying to fit as much power under it as possible without compromising the structure of the build. i.e. excessive cooling measures.
I'd say the overall space in the case is comparable to a u2.
So, considering heat concerns, I narrowed my CPU choice to either the i5-2500T or the i7-2600S
It's almost impossible to find benchmarks for these in DAW applications. So I am hung up on which processor to choose.
I run FL Studio which handles multicore processors very well... But I use a lot of 32 bit plugins.. and I am uncertain of how many or which ones are coded to really benefit from a quad core CPU. So I am wondering if I will need that extra clock speed...
Mind you I can run a 30-40 track project with about 40 instances of my heaviest plugins with my current E8500 Core2 (4gb DDR2) setup and it has quite a load but it doesn't flinch.
So what I really want to know... is can I get away with the i5-2500T? Would it be a significant upgrade from the E8500?? Or should I just go with the i7-2600S and roll the dice on any heat issues??
Thanks in advance!
Thanks in advance!
