lollysticky
- Aug 23, 2008
Fist off, the obligatory questions
Gaming. I want to play 'Stronghold 3, Diablo 3, Empire: Total War: Shogun 2' at a high framerate with enough details!
800 euro's. tax and shipping are not really an issue since the retail shop is nearby.
Flanders
CPU, GPU, PSU, RAM, CPU Cooler, MOBO,
I have a supply of keyboard and mouses lying around. Sound setup and monitor are also present.
6) Will you be overclocking?
Could be... depends on the temperaturs I will be getting inside the little box.
22 inch Samsung Syncmaster: max resolution = 1600 x 1050. I will be buying a new monitor in the near future (so bigger size + higher resolution)
At the end of this year, I'm hoping for some christmas/new-year price cuts
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0 seems to be my only concern at the moment.
I only own WIndows XP (32bit
I already went forth and selected some components I think are 'good'. I have chosen for brands that have not let me down so far (Gigabyte, Sapphire) and opted for some new ones (G.Skill; I have always opted for Kingston memory so far). The list:
1) CASE
Lian-Li PC-Q08B ( 89 euro )
- MB format: mini-ITX
- Case Size: 227mm x 272mm x 345mm (W x H x D)
- Video Card Size: max 300mm (when bottom HD cage removed)
- Top fan: 120mm
- Front fan: 140mm
2) CPU
Core i5-2500K ( 191 euro )
- 4 cores, 3,3Ghz
- 95W
- unlocked multiplier
- Integrated Intel HD Graphics 3000 (not that I need it, but it's only marginally more expensive than the i5-2400k so who cares about this)
3) CPU COOLER
Corsair Hydro H6O ( 61 euro )
- Connected to the top 120mm fan place
4) MOTHERBOARD
Gigabyte GA-H67N-USB3-B3 ( 91 euro )
- http://www.gigabyte.com/products/product-page.aspx?pid=3783#sp
- Intel H67 chipset
- socket 1155
- 1333/1066/800 Mhz DDR3 memory
5) MEMORY
G-Skill Ripjaws 8Gb ( 49 euro )
- DDR3 1333 Mhz (PC3-10666)
- Kit of 2, non-ECC
6) GPU
Sapphire HD 6870 Vapor-X 1Gb ( 186 euro )
- 2-bay, 9.5 inch (24.13 cm)
7) PSU (choice 1)
SilverStone Strider Plus Series ST60F-P ( 88 euro )
- 150mm x 86mm x 160mm ( B x H x D )
- Modular
- 600 Watt
- 2! 6pin pci-express connecters
8) PSU (choice 2)
SilverStone Strider Plus Series ST50F-P ( 68 euro )
- 150mm x 86mm x 140mm ( B x H x D )
- Modular
- 500 Watt
- 1 pci-express connecter -> splitter needed
9) PSU CABLES
SilverStone Short Cable Set SST-PP05 ( 18 euro )
10) HARD DRIVES
got two 300Gb SATA2 HDs lying around. Will update later on when HDs get cheaper again.
11) OS
-> I have only used XP so far for my gaming systems. I would like to move on..
so… Windows 7? Or Vista?? Or Windows 8 ? I have no idea as to which to choose, basically because I have occupied myself with mac and linux systems for the past three years
The questions:
- Will the H60 fit between the PSU and the processor? I have read it does, but I canot 'officially' confirm it.
- What OS to choose?
- Any comments on the GPU? An upgrade to a HD 6950 is quite a leap in $$$ as well so I opted for the 6870...
- Which PSU to choose? Should I opt for the somewhat stronger 600W one?
- any comments / remarks / .... are highly appreciated!
Flanders
1) CASE
- Top fan: 120mm
- Front fan: 140mm
2) CPU
- 4 cores, 3,3Ghz
- 95W
3) CPU COOLER
4) MOTHERBOARD
- Intel H67 chipset
- socket 1155
5) MEMORY
- Kit of 2, non-ECC
6) GPU
7) PSU (choice 1)
- Modular
- 600 Watt
8) PSU (choice 2)
- Modular
- 500 Watt
9) PSU CABLES
10) HARD DRIVES
11) OS
The questions:
