Advice in Choosing a Card
Blackjack
I am building a mid-range gaming machine based off of the Intel Retail Edge Program(Q6700, D33GTL, Vista Pro) and i was looking for a graphics card. I am a gamer however graphics are not my highest priority, i just want to be able to play most games. I'm not looking to spend more than 200-220. In particular i was looking between the Visiontek Radeon HD 2600 XT 512 and the EVGA GeForce 8600 GTS. The last card i bought was a Radeon 9600XT which i loved so im looking for an objective comparison between the two cards and any other that you may be able to suggest. Thanks in advance
I'm really not looking to spend that much and prefer to stay below the 200 mark. I'm just looking for a basic comparison between the two, i mean according to what ive read the radeo has a 800MHZ clock speed and the NVidia drivers suck with vista. So everything is pointing towards the radeon but that seems to be geared more towards watchin HD movies on an LCD tv rather than gaming.
No seriouly Blackjack988, get the 8800GT. We are talking serious performance difference.
Wait a bit, dont buy a mouse, whatever...
BTW, anyone seen any 8800GT with HDMI yet? I seem to recall that it had support for it.
In that case which version should i look out for...and any other special considerations?
Sorry about the double post but i also wanted to know about these stories im hearing about Nvidia drivers being incompatible with vista. I do want to use the card that i end up buying
Blackjack988, I run NVidia on Vista, and no issues at all. There might be some issues from what I recall if you are using SLI (not your case).
As far as which version, if you can wait a week or so and see what reviews are there, then I would do that.
As far as brands are concerned, man everyone has a diff opion, but the standards "seem" to be evga, xfx, bfg, etc...
But since you did not want to spend too much, might want to just go on price.
Try: http://www.google.com/products?q=8800gt&btnG=Search+Products&scoring=p&sa=N&start=0
Mind you, i like the peace of mind of known good support, and that is usually what really differentiates the diff vendors.
Hopefuly some one else has some specifics on particular models. but it is kind of early.
BTW, ultimately I hope you do your research for yourself. It is a key piece of your setup and and $200+ is too much money to go on any ones advice. Unless you ask Kyle ;-)
