Advice for Upgrade
It fried. I had a problem with the electrical box in my house that was misfiring. My PSU and mobo are both fried, so I'm planning on upgrading to AM2 platform for a cheap upgrade.
BFG 6600GT OC @ 589/1250 (just one for now until monitor upgrade)
Depending on GPU plans anything from a $38 XCilo 450W to a $127 Corsair 620W or higher would be recommended.
What GPU, now & in the future?.
I'm trying to go as cheap as possible for this system, so probably the 6600gt until new build.
Then the XCilo 450W at new egg for $38 is ideal. ;)
XClio 450BL ATX 450W [Dual +12V Rails] (Best Bang for the Buck!)
Max Combined +12V@???A, Not Rated for Temp, Efficiency >70%, ???yr Warranty
Specs: http://www.xclio.com/htm/products-PSU-450BL.htm
Review: http://www.extremeoverclocking.com/reviews/cases/Meridian_XClio_450W_1.html
$38: http://www.newegg.com/Product/Product.asp?Item=N82E16817189003
I have personally tested this PSU & I highly recommend it for low to mid-range systems.
