Advice for graphic designer.
strossos
I've looked through some threads here and tried finding what I needed in the scarce amount of reviews on the net for these monitors.
For graphics design, what monitor do you recommend. Obviously very good color depth and accuracy is required.
Right now it is SONY SDM-S205FB vs. the Viewsonic VP2130b
So far the Viewsonic VP2130b looks to be a decent choice. Good specs at least, 8-bit color and nice contrast/brightness. Couldn't really find any reviews on it though.
The Sony SDM-S205FB, decent enough on paper. Can't find if it 8 or 6 bits though.
Trying to stay <700, size 20 or 21 inch.
Edit: to clarify, I need something that will be the most accurate compared to what is going to be printed out.
I beleive the Sony uses an LG phillips S-IPS.
For graphics design I would choose the Viewsonic which is using a samsung SPVA (I've had experience with both types of panels and find the samsung more vibrant with better viewing angles).
Either choice you're probably going to need to calibrate the colours anyway.
