Hey guys -
I work at a local pc shop which is doing very well except for one aspects. Computers we sell.
Right now our "budget" machine which is just geared toward buisness apps consists of the following:
AMD 64 3000 or 3200 depending on sales, socket 939
MSI K8N without onboard and a X300 or a MSI/Radeon IGP with onboard
512mb Rosewill DDR, started using since with that Radeon board you get 2 512 sticks for an extra 70
then we put in a 80gig SATA usually Seagate but depends on sales
and the case is just a Black Antec Lifestyles.
We charge about 650-750 for these not including labor. Great computers with great results probably sold a few dozen but people want cheaper.
Most people see our estimates and then say "o but we see dells for 400 and so and so"
Being a small time shop no one can compete with dell.
What we want to do is get a computer to the 400-500 range. Something only for buisness, onboard vid is fine. 512 DDR is standard and the black Antec case must stay as they are easy to work in and look great.
We were thinking of a Sempron or Celeron system or something of that nature.
Not dealing alot with these cpus, we despise them, so we came here for advice.
We want Socket 754 if its hte AMD route, just because its mainstream, unless Socket A.
What do you guys recommend?
We need advice on really motherboard/cpu combo. The DDR Rosewill is cheap and works good. And harddrives are cheap.
Whats the best bang for the buck motherboard/cpu? We usually just go Asus or MSI, but again those are pricey. We want stable setups.
Thanks,
Dan
Thanks,
Dan
