1Wolf
- Jul 10, 2007
I'm in the process of building a new system that will have the OS/Programs on a 512 GB SSD and a 2 or 3 TB spindle drive for storage.
I was wondering if I could get some advice on what software to purchase for a good backup strategy?
I'm not very familiar with SSD's (This will be my first one) so its throwing me a bit of a curveball. On my current system (Windows Vista x64 & spindle drives only) I've had great luck with Acronis True Image Home.
Every few months I'd build a new image of each partition with Acronis, and then do an incremental image once a week. I'd store those images both on an internal HDD, as well as 2 external HDD's. One of the 2 external's I'd store offsite.
This has saved my bacon on more than one occassion and Acronis has worked easy and awesome for me in restoring an image. When my OS/Programs HDD croaked, I just bought a new one...stuck my images on the drive...and it was like nothing ever happened. Simple and painless. Acronis has been great to pull over individual files from the image as well on the occassions I needed to get something back I deleted.
I'm not sure what to do about my new SSD though. Do you guys still use imaging software? If so, can you save an SSD image to a spindle HD...then if you need to...restore an image from a spindle drive back to an SSD? Or is the image somehow 'not right' once you copy an SSD image to a spindle drive?
If imaging is still the way to go...what software do you guys prefer?
Any help or advice on strategies, software, do's and don'ts would be greatly appreciated.
Thanks!
Thanks!
