I got roped into doing a T1 cut-over the other day. The T1 router is an Adtran 3200 that needs to be re-programmed for the new circuit. I never worked on one of these before, but I figured out the CLI, almost exactly like a PIX.
I got the router setup well enough to show the circuit is good and for them to activate it. I had to fall back to the old T1 due to a problem though.
The one problem I'm having is that I can't change the local IP of the router itself through telnet. Every time I enter the new IP it drops the telnet session immediately before I get a chance to save the config. The box will not re-connect under the new IP either. So the box gets stuck in limbo and I have to re-power it to get back in under the old IP.
Is there a trick to do it through telnet, or do I have to go find a console cable?
