- Jun 15, 2005
The newest Adrenaline driver version 24.9.1 finally allows frame limiting in conjunction with AMD fluid motion frames for a massive increase in FPS while reducing power consumption in more demanding games. I haven't really tested it much but so far it is very impressive and it's working on 6000 and 7000 series gpus. Release notes say it's working with chill enabled but not really working for me. I found that if I set my in game FPS limit to 50% of my panels refresh rate it's working perfectly. This should make some of the high res high refresh gamers happy though and I can't feel any additional latency as old and slow as I am. I recommend you give it a try as it only takes a few minutes and you may be pleasantly surprised.
Highlights
New Game Support
- Frostpunk 2
- God of War Ragnarök
- Warhammer 40,000: Space Marine 2
- The Sims™ 4 DirectX® 11 Update
AMD Fluid Motion Frames (AFMF) 2
- A major advancement in frame generation technology for AMD HYPR-RX.
- Lower Latency and Higher Performance
- AFMF 2 enhances fast-paced gaming by significantly reducing frame generation latency and improving performance scaling through new modes.
- Fast Motion Optimization
- Enjoy smoother gameplay and higher FPS with improved frame generation consistency during fast motion.
- Improved Borderless-Fullscreen Support
- Expanded display mode support for RDNA 3 series graphics products ensures compatibility with virtually all borderless fullscreen games.
- Expanded API Support
- AFMF 2 can now be enabled for any OpenGLNEW, VulkanNEW, DirectX® 11, and DirectX® 12 titles.
- Radeon™ Chill Interoperability
- AFMF 2 now supports Radeon™ Chill, providing a low-latency FPS capping option.
- Optimized AMD Ryzen AI™ 300 Series Support
- AFMF 2 is optimized for an extensive list of AMD products,
