Adobe Reader and Acrobat Security Initiative
HardOCP News
[H] News
Adobe’s Director of Product Security and Privacy made a blog post today that says his company is working on security and a new way of delivering patches and updates.
Since February, Adobe Reader and Acrobat engineers have been executing a major project focused on software security. Everything from our security team’s communications during an incident to our security update process to the code itself has been carefully reviewed. Security is an ongoing process, so while we believe our plan will eliminate or mitigate many potential security risks, we are also working to enhance our ability to respond to externally found vulnerabilities in Adobe Reader and Acrobat in the future.
MS should have a service where they can push your updates through Windows Update. Charge a company like millions of dollars a year for this. They simply give the update to MS and they add it.
Throw in a disclaimer that the update was not tested by MS and that they are under no obligation to provide support if issues were to arise from non-MS updates.
I'd much rather deal with that then the stupid Adobe updater, which I have to disable everytime I update Adobe Acrobat Reader.
The problem is though, the first time that something like that screws up somebody's machine they are going to blame Microsoft and not adobe. After all Microsoft is the one that gave it to them.
Also most probably wouldn't like that as they like to prompt you to install all the extra crap along with their programs to make money. If they paid Microsoft AND lost the money they make by people installing the 9 toolbars that come with programs then they would really be losing money.
In the case of Adobe upgrading you from one major version to the next would be a plus. I have seen a lot of machine that still have v6 or 7 because Adobe never prompted them to install the next major release. Firefox does the same thing. It should prompt you about major updates just as it does minor.
God, about damn time. If a new flaw every two weeks wasn't bad enough, patching their bloody software is a nightmare. Broken installs, prompting for .msi files constantly when they there, Adobe won't even give out a network installer without jumping through tons of hoops. Theirs is the most horrid software to manage on any network.
The problem with having it prompt you, is the requirement of a listener to run in the background. Adobe has such a thing to check online every so often to look for updates. It annoys me, so I disabled it on my own machine.
Maybe instead of storing the update files on Windows Update, instead have the service check what programs you have and inform the user that there is an update and provide a link of where to get it. More work for MS, but they can just pass off the cost to other companies that want to hop in on it.
I hate Adobe Reader. Just use Foxit reader. Its free and is extremely small, unlike Acrobat that is huge, bloated and constantly has problems. I use Foxit on my personal machines as well as my system at work. The only PC that I oversee at work that I still use Acrobat on is one that my techs use because their work shop manuals require other Adobe products.
