Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
the audio codec for your file is not installed/supported by adobe premiere. i've had that happen multiple times, i had to re-encode the video into raw avi before i could properly import it into premiere. it sucks, i know, but if anyone knows how to actually fix this problem rather then avoid it, please post!
This is so messed up, this worked a couple of months ago, and I was still using K-Lite Codec Pack, is there another Video Editor that anyone can reccoment that is compatible with Vista, i tryed Pinnacle, but it wasnt supported by Vista
