adobe acrobat sucks
my mom reads a lot of PDF documents for her work, her clients and people she works with always send her PDFs, she checks her bank statements online in PDF format, and acrobat reader never works. before it'd take around 5 minutes to load, then i did the trick where you move all the plugins into the optional folder, so it loads faster. now all it does is freeze internet explorer whenever she tries to open a document. are there any other programs that can read PDFs? is there any way to make acrobat reader stop sucking?
actually yeah try Adobe Reader SpeedUp it is a simple application that was created to help make the loading time of Adobe's Acrobat/Reader software bearable for everyday use. AR SpeedUp only needs to be used once (a process taking only a few seconds) and then your 'Reader will be transformed forever. There are also some tweaking options available. "w00t!", as the young kids say.
Search google
6.0 is bloat, so try 5.0. It isn't quite so much bloat, and it works well...opens way faster, too.
unfortunately the adobe site doesn't seem to have 5.0 available for download anymore. Isn't there any alternative pdf reader/viewer that's small and lightweight? I was just looking at acrobat reader 6.0 and it takes 45 freaking megs! What the hell?! 45 megs for a god damn reader?! You have got to be kidding me! I use to have 5.0 but lost it in a hd crash. As I recall, 5.0 wasn't that small and lightweight either but at least it's not as bad as 6.0
Thanks
I know that someone is going to consider going back even further to 4.0 because it is way quicker than 5.0. Before you do that, realize that it won't open some of the newer .pdf files out there. I know for sure because I tried it already.
Search google
Dude, seriously, i wish i had these the first 2 years of college. Nothing pisses me off more than waiting around for acrobat to load. Thanks again man.
Thanks for the link. I downloaded acrobat 3.0 and it seems to work ok with the ebooks I have. And it comes to less than 6 megs after install. Now that's more like it :D
Just a warning, but I have to deal with acrobat 5-6 issues a lot. There are known issues opening acrobat 6 documents on reader 5. The problems include slow printing and not being able to open the document.
The printing issue can also be a drivers problem where the graphics get printed in an uncompressed format, IE a simple 10 page document can be 40MB to the printer. I'll take a look at that speed up thing, could be pretty usefull.
Seems like just about any cd you get nowadays will have some version of adobe reader on the cd.
I'm trying to keep our users on v5.05. It's only around 5 megs and haven't run into any problems with newer/older files. Anything older than 5 and you'll eventually run into a display issue with a pdf file.
First thing I do when installing adobe is disabling the extra crap such as "auto check for updates" and that kind of stuff.
Search google
Thanks for the heads up on this. It is a "must have" tweak. I can't believe how much it speeds up the program! :)
I have Acrobat Read 6 on my work machine and it is dog slow. I hate it. In our department we have one license for Acrobat Professional 6 and the guy that uses it does not have the same issue. His documents open really fast. Is this an issue between the reader version and the writer version?
5.05 here, had it for years ( i never format). loads very fast . winzip 8.1 aswell.
adobe photoshop takes the piss but its not too bad, mozilla firefox is the ultimate pisstaker. takes forever to load up.
Maybe the pro version loads the plugins only as it needs them. That's what slows down the free versions. I use 5.01, and the tweak made it load well over twice as fast. The way it works is by modifying AR, so the plugins don't all load when the program does. AR still has all of its functions, however. Very nice. Why Adobe doesn't do this already astounds me. :rolleyes:
On my system PDFs open slower with the full version, because the full version loads more APIs than reader. I can't see how it would ever open faster, unless the list of APIs was reduced (which is what that AR Speedup probably does, this can also be done manually).
Reduce APIs Plugins to load Acrobat faster.
Right. That's exactly what AR Speedup does.
This affects me a lot because I produce an online zine in PDF format.
The trick I've found is that Acrobat is faster & more reliable
outside a browser. So download those PDFs, then open them directly,
without the web browser.
There is also a check box in acrobat where you can specify it not to open in the browser.
