Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Are there any ill effects of increasing the 3.3v rail over the long term? I'd like to pump 3.3v at the most through my RAM, so I'd need to adjust it up to 3.4-3.45. Also, does anyone have a write-up or guide for doing this on the PCP&C 510's?
Yes, but I can only as high as the PSU is able to feed it. The most it recieves at this point, without adjusting the pots, is 3.15v actual vdimm, regardless of whether I set it higher.
