- Jul 11, 2001
Heres my problem. Right now Ive got 6 storage drives in my fileserver. 2 120s, 2 200s, and 2 250s. Each pair is in Raid-0.
What Id like to do is get rid of the mismatched drives, and either get a number of 200s or a number of 250s and make it Raid-5. My problem is that every time I change my storage around, I have hundreds and hundreds of gigs that I need to put somewhere and that isnt always possible. Im thinking for an initial Raid-5 configuration I would go with 3 250s. My main concern is that that is 500gigs of usable space, and if I ever wanted to add more 250s to the array, I would have to find a place to store that 500gigs while I rebuilt the new array. Idealy this will be using software raid in windows server 2003 because the cost of hardware raid-5 is pretty high and performance isnt really a factor here.
So, to solve my problem, does anyone know if there is a way to dynamically adjust a Raid-5 array, like, have 3 drives, add a 4th and have it automatically incorporate that drive into the array without having to pull all the existing data off and rebuild it from scratch?
