Adequate card for cod4 on high settings
tgabe213
I've got an 8600gt right now, and of course it can't handle a lot. Settings are pretty low for cod4, and I really want to see what the game can be like.
e6550
3gb ram
8600gt
psu is standard that dell throws in inspiron 530's
22" Acer 1680x1050
I'm not really sure what card will give me all of this. Budget: ~$150? I'm thinking my best bet is to find something used in the FS section, like the 8800gts 640mb that was in there yesterday for $140 or whatever.
What in the 8 series is that card equivalent to? I thought I saw that it is better than the 8800gt. Will my psu be ok? I'll have to check on exact specs tonight.
Here's a pic someone took of their 530's PSU. I *should* be the same. Will verify tonight though.
PIC
if you look around you can find teh 9600gt's for $130-$140. I just got the XFX 9600GT with a E2200 Stock and 2 Gigs of DDR800. I am able to run COD4 at my native res of 1280 x 1024 with everything on/maxed and rarely go under 80fps. I have seen 65 fps but that was when a air strick was going on right in front of me in the rain and tons of players around. i dont have a overclock version either so I am very pleased with my 9600gt.
Ah, sorry. I'd prefer to play at 1680x1050, which is the native res of my 22"
I got a used XFX XXX 8800GTS 640mb here for $180 used. That card will do COD4 at your resolution.
I will run mine 1920x1200 2X MSAA,Extra textures, 16AF w/ most effects off. That means you have headroom at 1680x1050.
