I've got a machine that pretty repeatably fails memtest. The error is around a particular address all the time; 0x000027Bxxxx. It always happens, though it usually takes several passes to expose the error.
Is there a way to determine, from the address, which memory stick is the problem? Or will I have to remove a stick, test again, and try to eliminate the bad stick by re-testing?
