- Jul 11, 2001
I currently run 4850 crossfire. There are a few issues Id like to fix.
-I cant overclock the cards while using dual monitors. If I overclock even one Mhz the screens will start to flicker and the display driver will fairly promptly crash. I understand that this is an issue with the idle clocks on the cards and I can fix it by using a custom bios that keeps the cards at 3d clocks, but I dont really want to load a custom bios on the cards. Right now I can only overclock when using a single monitor.
-Although I use 2 monitors right now, Id like to add a 3rd. I can only use more than two monitors with my 4850s if I disable crossfire.
So I picked up a x1300 PCI card. My idea is that Ill just use my 4850 for my main monitor and have the x1300 handle both the 2nd and 3rd monitors. Hopefully this both allows me to overclock my 4850s and run 3 monitors.
My problem is that it seems the newest driver for the x1300 is the 9.3.1 legacy driver:
http://support.amd.com/us/gpudownlo...spx?type=2.4.1&product=2.4.1.3.7&lang=English
That has me a bit worried. The 9.3 driver would probably work fine on my 4850s but I like to stay current with my driver just so that I can have the best crossfire support in games. On the other-hand, could it just be that those are vista drivers and they are referring to the Vista limitation of not being able to load multiple video drivers?
I was under the impression that you could, for example, have an ATI and Nvidia card running side by side in Windows 7. If that is the case it shouldnt be much of an issue running a newer and older ATI card, right?
Any customers using a combination of a ATI Radeon HD 2000 Series, ATI Radeon HD 3000 Series, or ATI Radeon HD 4000 Series product with any of the legacy products listed above in a single PC system must use the ATI Catalyst 9.3 or earlier driver. All future ATI Catalyst releases made available past the ATI Catalyst 9.3 release will not include support for the legacy products listed above or any of the features associated with those legacy products.
