Adding Window to a V1100?
no, the side are not compatable. i may need correction on this but i am pretty sure the 1000 and 1100 are the same case other than the 1100 is something like 2-3 inches longer.
the 1000 series panel will fit the 1100, but the 1000 panel has rounded corners, the 1100 corners are square. i had a 1000 panel on my 1100, looked a bit goofy. im looking for the 1100 panel with the vent, if ya find anything lmk.
i think its the v1100+ II that has a vent got that site it had them, also u can check an option to add one at that same site
