Adding Vista to new system with XP Pro . . .
dgsg
Purchasing a new system with XP Pro installed from those who shall not be named. If I purchase Vista Home Premium OEM to install as a dual boot, will vista create the extra partition during the installation, or should I order the system with (2) partions already on the drive? I would take the chance on Vista only, but my slide scanner is not supported and never will be it seems. :(
Backup your data before you begin if you havent. I would partition and format first, then install vista
Hard Drives are cheap now days, get a second hard drive you'll be glad you did. i run 2x120 seagates, xp on one and vista on the other.
