Adding vid Card And turning off Intergrated Graphics.
Hades12
I have read the stickey on changeing ATI to ATI or NV to NV and ATI to NV.
But I am going from intergrated to an ATI card,
What is the best way to make the switch?
Thanks
When there's no option to turn it off in CMOS setup, the method I use is:
Leave the monitor plugged into the integrated video VGA port and boot into windows. Uninstall the integrated drivers, don't reboot. Go into device manager and disable the integrated video device. Shut down the system and install the new video card.
Well as pxc mentioned, disable it in bios, install the card, or if there's no option to do that in bios, do what he said in the post.
I like to remove the integrated graphics with what I call my Device Manager, also known as vice grips and my foot. Works well, although the results are mixed.
I tried that once, But the board did not want to boot afterwords.
Reformatting with your new card makes windows completely ignore the integrated card.
Without a format your card will be viewed as secondary. Not that it makes a difference.
I added a x1800xl to my MSI MS-7184 with an x200 it did everything automatically but until I reformatted windows did catalyst start working smooth.
