Jan 29, 2005 #1 O Olaf Limp Gawd 2FA Joined Dec 30, 2002 Messages 229 I have an Abit IT7-Max 2 mainboard and would like to add a third hard drive. I have two hard drives on ide channel one and two cd/dvd drives on channel 2. Can I add a third hard drive to channel 3 with out using raid?
Jan 29, 2005 #2 B blink182prj Weaksauce Joined Nov 28, 2004 Messages 92 Sure...buy a PCI IDE controller card. They run ~$15 at pricewatch for a cheap one.
Jan 29, 2005 #3 D Dan_D Cat Can't Scratch It Joined Feb 9, 2002 Messages 66,323 Yes you can add one to the third port without using RAID. There is also no need to buy a controller card if you have more than 2 EIDE channels.
Jan 29, 2005 #4 O Olaf Limp Gawd 2FA Joined Dec 30, 2002 Messages 229 Do I just set new drive to master and plug it into IDE channel 3 and use windows disk manager?
