Adding mobo cooling to striker
sd11
Currently I have EK CPU 775, 2x EK 8800gts, swiftech 320, D5 pump. It works fine but stripped of the fan on the CPU HSF the strikers stock cooling isn't that impressive (and frankly wasn't that impressive before). I'm looking to add 2x EK NB/SB coolers, and 2x EK voltreg coolers to the existing loop, seeing as I don't have the space for another pump + rad.
The board is not heavily OC'd. So the real issue is how much of a temp rise will I see, and will I require to change the radiator out for a larger one.
