Adding mirror on bottom of case...
Worminater
What i'm looking to do is get a mirror or similar finish on the bottom of my case (x-dreamerii). Is there anything I would need to take into affect to do this? I have ~3/4 of an inch clearence on the bottom of my case to play with, and i have alot of wires there to (want to hide them)
Anyone have any suggestions for materials and what to/not to do/what materisl to/not to use? I have never attempted something like this and am not sure where to start. its the rig in my sig btw; and i think i want to have a cathod mounted on it to enhance the affect to so... yea. Any suggestions?
just get an actual mirror and raise it up with rubber pieces. You can get mirrors at glass shops or HomeDepot-like stores, the tool to correctly cut the mirror can be found there also.
That, or if you dont feel skilled enough to not break mirrors (any supersticious people round here?) while cutting them, you can actually have the people at home depo / lowes cut teh mirror to your measurements. I think it would be cool... kinda like the chiller sections at the grocery stores
I don't think they would be able to make any complex cuts, just rectangles. I don't think they could cut notches or what not into it. I believe they have reflective sticky film, you could cut a piece of aluminum to shape, then apply the film.
go buy a piece of mirrored acrylic at tap plastics. You can cut, bend, whatever.
break a mirror into many pieces and shove em into the bottom of the case...
lol. His Executive Top Window Kit looks like a Maxi pad w/ wings.
Sorry, that wasn't constructive. I found it funny though. :p
if you can't get a hold of mirrored acrylic, I can get it for ya, tap is right down the street from me.
