I currently have a 1 gig kit (2x512) of ddr4 OCZ platinum rev2 going at 2-2-2-5 at 2.75 volts.
http://www.ocztechnology.com/products/memory/ocz_el_ddr_pc_3200_dual_channel_platinum_rev_2
I want to add another 1 gig in my computer but I can't find this ram anywhere in Canada anymore.
So I was wondering if I can put this OCZ memory which runs at 2.5-3-3-7 at 2.6 volts :
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=587478&CatId=10
Will I be able to run both memory kits at the same timings and the same voltage ? Will I have compatibility problems between these two kits ?
Btw, my motherboard is an Asus A8N-E with an AMD Athlon64 X2 4400 toledo.
Thx for your help.
Thx for your help.
