Adding in more drives
Blackjack
Alright, so i just recently purchased 2 400GB SATA drives to add to the rig in my sig and i was wondering how i should configure them. Originally i was planning on setting them up in raid 0 and running my games and OS off of them putting all my data on the 500 gig that i already have. Now i realize the risks involved with RAID 0 and since there is no extremely critical data (none that isnt backed up) i think that it would be a viable option to increase the speed of data transfer (at least for large files). I don't want to buy any additional cards so i would be using my 680i's built in RAID.
1. Would this be a better option than going with 3 separate discrete drives?
2. How the hell do you set up a RAID 0 array on the 680i as the manual is...cryptic...at best.
Thanks in advance.
P.S. The drives are Hitachi with model number hds724040klsa80 (bought them off computerpro3)
I'd keep them separate and save myself from the headache.
I would keep them separate as well, I ran XP in RAID 0 for 4 yrs or so, now I run Vista on a raptor, games on on a raptor and Virtual Pcs/Newsgroups on a third hard drive. Keep things split up so that if you decided to download something, game and do updates, you won't be slow because of the hard drives.
