Adding HS's to MB Question
Top Nurse
Does anyone know if it would help to add HS's to the voltage regulators (VR) that control the voltage going to the system memory?
I have already added HS's to the VR's that feed the CPU. I also have added a HSF to the SB as well. This would be for my A7N8X-Dlx H20 cooled (CPU and NB) board.
yes, yes it would
**damn i re-read it, i'm not sure, i thought you were talking about the one's around the proc.
bump
BTW, I believe MOSFET=Metallic Oxide Semiconductor Field Effect Transistor. MOSFET's are used in a variety of semiconductor applications most commonly as power amplifiers. However I believe the use on computer boards is to act as a voltage regulator (VR)...not Virtual Reality <smirk>.
