Mmats said:I want to add a domain controller to an existing domain but I noticed dcpromo says it will delete all local user accounts. What will happen to applications that startup using the LocalSystem account?
Mmats said:Ah gotcha, and what about the IIS accounts with prefixes "IUSR_" and "IWAM_"? I guess I have to go through the IIS settings and set it to use different accounts?
feigned said:I'm thinking that the accounts will migrate, but I'm not 100% sure on that.
Are you applying permissions or doing anything weird with IIS? I wouldn't sweat it if you're not.
Mmats said:Well the machine in question is running iis services for the internal lan, its a web server with a few virtual directories that have permissions that arent default.
